Alternative use of IronX
gmck
I was preparing a 2005 Honda Accord for a paint correction and accidently came across an interesting use of IronX.
This particular vehicle, although a very low mileage vehicle (15k) was absolutely filthy. It took most of the day just washing it, cleaning the wheels and getting the interior presentable. I doubt very much it had been washed all that often during the last 6 years.
After all the cleaning, I started claying the bonnet in preparation for the compounding and found a couple of spots that I thought IronX might help. Unfortunately the IronX didn’t do anything for the particular problem spots, but the side affect of using IronX was very interesting.
I’m always experimenting with various cleaners trying to find something that will really kill any polishing oils, previous sealants etc prior to applying Opti-Coat to a perfectly polished surface. After spraying the IronX on the bonnet, I was interrupted by a neighbor and while we were chatting it started to drizzle, so I ended up leaving the IronX on the surface for about 15 minutes. I then noticed that the surface had gone dead flat with no evidence of any beading as compared to the rest of the vehicle. To take it further I then spread the IronX over the bonnet with an MF and let it dwell some more and then rinsed off. The surface was absolutely flat – not a hint of beading, squeaky clean and therefore a perfect preparation for Opti-Coat when I done with the polishing.
Not only perfect, but also economical, a couple of squirts per panel, rinse off and you are done.
Theres a new product coming from CarPro called Eraser which is a pre-coat or post polish cleaner that removes oils and preps the paint for bonding with Cquartz. I'm assuming that it works for cleaning before applying other sealants and coatings as well but I'll get clarification on that.
I've noted that iron x can strip a fresh KAIO application
whether it is b/c the protection left by KAIO is not very good or it had not been given enough time to cure after application, was not determined, but it was an interesting observation during other testing I was doing.
I've never used Iron-X...yet.
Your results are intriguing and sounds like it's stripping any sealants or wax that may have been applied. I say "sounds like" due to the way you've described the condition of the finish.
A dead flat finish could indicate oxidation and using a 1-step product at the bare minimum would be recommended. Any topical protectant such as Optimum Opti-Coat will take on the surface characteristics its applied to. If the surface is polished to a glossy shine then the Optimum Opti-Coat would give a wet appearance. If the surface is dull and lifeless then this is what the protective coating will emulate.
:hungry:
Hmm.
Sounds interesting for sure .... Is this one of the company's you are working for Corey? How exciting if it is, they are on the move for sure!Im the MANLook forward to your review!:buffing:
Hey Corey,
Will this Eraser leave a clean but conditioned surface like some of the prewax cleaners?
Eraser
Looks like with CarPro Leather and this product is not on the market yet. Thanks for the heads up Corey.
Hey guys, I spoke with Avi and he said yes it is specifically designed to use after polishing your paint and before applying CQuartz but you can use it to clean the surface before applying other products (waxes, sealants, etc) as well. It gets the surface entirely clean and doesn't leave a residue.
Btw: I have to apologize now. I really didn't mean to threadjack. Initially I just thought it was relative to the OP's subject. Sorry about that.
