Hi,
I have been searching for a solid solution to the problem of oxidation on aluminum parts in my Corvette engine bay. The alternator has some oxidation on it and I have tried to wipe it off but it looks like it will take a little more serious effort. I would like to get this white powdery looking oxidation off of it and other aluminum parts in the engine bay area. In your area on engine detailing and in other forums there is discussion about covering and protecting the alternator and I want to make sure I don't damage it while using polish, water, or any number of the recommended fluids to accomplish the job... and there have been several. If it were not the alternator, I would be less wary.
What is your advice on removing this oxidation, process and product wise. Once removed, what is the best protectant to use to help maintain a clean finish? I have heard of everything from WD40 to a range of polishes.
