I'm new to this cleaning, detailing, and polishing world, so looking for advice - you won't offend me by dumbing it down, in fact I need that!
I have a 1965 Seven. The aluminum portion of the body was originally painted, but was scraped and stripped in about 2008 - with little to nothing done to it since. It is in ok shape, oxidized and a bit flat, looks better in pictures and from afar than it is. Well-patina'd, and will never be perfect without a reskin (it is 56 years old, after all). The fiberglass nose and wings were repainted a couple years ago and are in quite good shape.
I've spoken with a couple local detailers, but am not convinced they really know what they're doing with aluminum polishing - and when I got quotes I started thinking, if I can rebuild the suspension and rebuild the engine (it is out for that purpose currently), I should be able to figure out how to clean and polish as well. And I'll need to know how to do this if I want to keep it looking decent without spending a fortune in detailing.
Based on advice from someone who does know aluminum, I now have a cyclo polisher that I'll use to polish and maintain the alu. First pass, though, I'll use a more traditional polisher to compound it. I'm planning to use Nuvite products for both compounding and polishing. I feel reasonably comfortable about this process, but welcome any advice, warnings, and/or tips.
My questions are about sealing the aluminum - is that worth doing, or better just to plan to polish every 6 or so months? if yes to sealing, what would you recommend - and can I use the same to seal the paint? any warnings or reasons not to use the cyclo on the painted fiberglass (with different pads)?
I've buried myself in many of the articles and videos (thanks Mike!) and ordered some decent microfibers for washing (waterless, for obvious reasons) and removing residue, etc., so getting somewhat comfortable with the basics - but realize I don't know what I don't know. So, what should I know before launching into this project?
As for desired finish - I'm not looking for concourse, this car will never be that again unless I reskin it and paint it (maybe one day, but no time soon) - it is just too flawed, and I actually like the patina. Having said that, I've come to learn that while the oxidation may serve to protect the alu to some extent, the contaminants on the surface will corrode and damage it over time - and that the only real way to address those issues is to clean, compound, polish, and then keep it reasonably clean. The car will live inside and not be used, to the extent I can avoid it, in poor weather, but will be a driver and not a garage queen.
Thanks in advance for any guidance and advice,
Henry
Henry
