Aluminum - Galvanic Corrosion
chefwong
Active member
those that see paint more than just the own fleet of mind
What's you take on the current state of paint / aluminum panels
Water based paints IMO chip more and in the chips I've seen, some of them are (chiiiips) and just not a little divot here and there from usual driving conditions.
In your opinion, is the current state of paint on aluminum accelerates wear faster.
Instead of a paint chip with primer coat still intact and eventually u see a rust spot develop on steel panel
vs.
Galvanic corrosion on Aluminum Panels
