I always top mirror polished aluminum with 845. I specifically instruct vehicle owners to clean tires and wheels with same car wash soap that they use on paint. Otherwise it wont be long before you have this: 7 months of oxidation (dd, outside 24/7/365) and overspray of APC used for cleaning tires.Hey guys,
Im looking for a tire cleaner that will not haze the surface of mirror polished bare aluminum wheels.
I tried optimum power clean but it left white spots on the wheels where it dripped, (was not used in the sun, did not allow to dry).
Thanks!
I think Duragloss 701 is not alkaline. I might try that.
This may or may not assist but alkaline products with sodium hydroxide (caustic soda) are the grim reaper here. If in doubt, get a copy of the MSDS and check - if it lists it, you would be wise to avoid it.
1.) Duragloss #701 contains Potassium Hydroxide---also a strong base, along the lines of sodium hydroxide.I think Duragloss 701 is not alkaline. I might try that.
I believe that's incorrect. I just read the description. It's not "strictly" alkaline.
