Am I missing anything?
Karcher X series Pressure washer
MTM Foam Cannon foam cannon
75 gal water tank water tank
honda eu200i generator
CG Maxi Suds Soap
Bucket
carpro wool mitt mitt
gold plush micro-Chineelle wash mitt mitt
Grit Guard Pad Washer pad washer
Micro fiber towel
Micro fiber towel still working on it
Micro fiber towel
Mothers wheel brush combo brushes
Daytona speed master jr brush brushes
Blackfire total eclipse wheel dressing
ONRWW rinseless wash
Iron X Decon
DP clay clay
3M trim tape 3 pac tape
Optimum metal polish metal polish
M101 Heavy compound
Optimum Polish 2 medium/light compound
HD Speed AIO
CG EZ crème glaze glaze
Optimum Opti-Seal Sealant
Sealant Upgrade sealant?
Collonite 845 Wax
Blackfire BlackICE Wax/sealant
Griots V3 DA DA
pads
pads ????
pads
Indigo 6 inch microfiber bonnets bonnets
DP Engine Degreaser engine degreaser
DP trim detailer Exterior trim detailer
metro vac n blo vacuum
VX 5000 (renny upgrade) steamer
Sonax upholstery cleaner carpet cleaner
mothers VLR vinyl/leather/plastic protectant
quikshade instant canopy (custom) canopy
I'm getting down to the final list of what I need, this is what I have so far. If you can think of anything else I might need or don't actually need let me know.
I'll have the vx5000. Do you think I will need the Sonax for the heavier stains?
I know ONRWW can be diluted for glass cleaner, spray detail and clay lube. What ratios do you guys use and can it be used for anything additional?
thank you for the input guys.
I don't see an APC? If I were you I would skip the detailers pride engine stuff and get a gallon of Meguiar's APC+. It will do engines, wheel wells, tires, wheels, carpet pre treatment, carpet spot cleaner, etc. etc..
-what about a pump for the pressure washer?
-APC? look into a super degreaser and a normal apc
-ditch the engine/exterior cleaner.. thats what the apc is for diluted at the correct ratio. ie 1:1 10:1 4:1 etc
-5" backing plate and 5.5" pads larger areas
-3" backing plate and 3.5" pads for tight areas
-for the foam cannon you should have solution for stripping wax and solution for normal wash
-leather aio
-again, the sonax could be ditched for the apc diluted the correct ratio
-you should use distilled water for anything you dilute
-when adding solution into the cannon, make sure its warm water
-metro vac n blo vacuum- i would ditch that and get the sidekick for the tight areas.. people say the blower on that is weak.. but look into that
-medium and agressive grade clay.. you never know..look into the speedy prep towel
-extension cord
-make sure your generator has enough power for all your equipment
-different light to inspect paint and light the area of work. i.e. brinkman, led, halogen, headlight
-any brushes in mind? for the cracks, grills, vents, cup holders, handles, etc..
trying to give you as much suggestion as possible
Polishers DA & Rotary
Brushes wheel, tire, interior & engine bay
Air compressor for compressed air (interior work)
D151 AIO cleaner/wax
Will the megs D103 APC be enough to remove most carpet spots or should I still get the Sonax?
The megs APC will do everything and more the Sonax will.
