The Guz
- Jun 17, 2013
- 8,769
- 46
Over the past couple of months I started to venture off and try other rinseless washes on the market. Running low on N914 helped that out along with the Southern California drought which led to water restrictions. It is a repeat of what happened 15 years ago.
We will break these down individually to look at the differences between the two.
American Detailer Garage Wipeout:
American Detailer Garage Hybrid Wash Rinseless Concentrate 16 oz.
Wipeout is the typical rinseless wash concentrate. It is a versatile product like most rinseless washes from rinseless, glass cleaner, waterless and clay lubricant.
These are the dilutions for each. I typically use it a t 1:256 for a rinseless wash.
Rinseless Wash: 1:384 | 1:256 | 1:128 (depending on desired cleaning ability)
Waterless wash: 1:32
Clay Lubricant: 1:10
Powerful Glass Cleaner: 1:256
This uses polymer chemistry to clean the surface. People tend to freak out when they hear polymers and the go immediately to this is leaving some sort of protection behind. Again don't focus on that. The polymers are there to encapsulate and emulsify the dirt making it safe to wash the vehicle. This among other rinseless washes that are designed to clean are not designed to leave protection behind.
Wipeout does a good job as a rineless wash. It checks the boxes for cleaning and doing it safely. It does a very good job at cleaning interior glass.
I will leave slickness but that quickly dies off.
I go over the demonstration of Wipeout in this video.
American detailer Garage Fuzion
American Detailer Garage Wipeout Fuzion
Fuzion like Wipeout can be used as a rinseless wash. But it can be used during the regular wash process thus being called a hybrid wash. It also has the ability to foam if used in a foam cannon or a foaming pump sprayer.
Like Wipeout it uses polymer chemistry to clean the surface.
The dilutions are the following. The Autogeek page has the incorrect working so this is taken straight from the American detailer Garage page.
Rinse Free wash 128:1
Quick detailer 20:1
Glass cleaner 20:1
Exterior Pre soak 20:1
Foam cannon. Full Strength (no dilution)
Fuzion does a good job at cleaning the paint and doing it safely like its counterpart wipeout when used as a rinseless wash. More product will be used if it is being used as a rineless with the 1:128 ratio compared to 1:256 for Wipeout. The benefit to Fuzion is its ability to foam. It tends to sit on the paint longer with it being foamed making it a good pre-soak.
Here is the video for Fuzion
Final Thoughts:
Both are good products and both do a good job. I would recommend having both and investing in a foaming pump sprayer. One preference that I do hae is using Fuzion as a foaming pre-soak and coming hack with Wipeout during the rinseless wash. I have this in the queue coming up soon.
Quick detailer 20:1
Glass cleaner 20:1
Final Thoughts:
