Annoying dirt on accord dashboard !!! Any advice
Honda Enthusiast
My accord dash board has an oval uneven shine when I use any dash board protection, i tried all types of products and I clean the dashboard with meguiars interior detailing, it keeps making this uneven white dirt. It is something you can see however when you put your hands on it, you feel nothing. any suggestions
As others have said, it appears to be the outline of the airbag. Have you tried multiple coats after cleaning? That can help even it out a little
It is definitely the airbag. That section will always appear like that as the dash material is thinner in that area to allow the airbag to break out of the dashboard upon inflation. The thinner material means that area is not flat due to gravity and expansion/contraction with temperature differences. So what you are seeing is shadowing or the light being caught in different directions, not uneven product. Function>Form
RE: Thinner material
I can almost buy into the expansion
& contraction...with the temperature
differences...explanation.
However...The area not being flat...
due to gravity...not so much.
Yep airbag outline area where it will split when they go off
I have the same thing in my Toyota. I've found that matte products such as McKee's Fast Interior Detailer work better than "dressing" type products that have more of a sheen/shine.
