IMO Cquartz UK 3.0 or Cquartz SiC. Both are super easy. In fact lay down a layer of UK then SiC. What's nice is when you use CarPro Essence, it is not only a polish and filler product that enhances gloss and the micro swirls polishing puts in but it's a base-coat layer of SiO2 for the next layer/your coating. It leaves a slick surface but that's not the end of it. When you put on UK 3.0 the surface becomes a slight bit more grabby vs Essence so you can literally feel where you need to coat. If you layer SiC on next, it goes on super slick and thus you can again, feel where you have UK 3.0 as your first layer and then SiC as your second.
Flash times will vary but UK does allow for longer and is more forgiving. However, you won't have a problem with SiC. Both have carrier solvents that are easy to wipe.
Whats the water behavior like for poorboys Mike? Its a great price for a claimed 3 year coating.
