ShineTimeDetail
- Sep 26, 2010
- 2,032
I have a 5000 watt coleman Generator with a briggs motor. It is fairly loud and I'm wondering if anyone has any tips to quiet it down. Do they sell quiet mufflers?
Just hook a 3500watt inverter up to your car battery and leave the engine running and you will be fine that what i did.How many batterires would it take to run an inverter strong enought to run an air compressor? I wouldn't mind going that route if it wasn't a million batteries.
Your generator runs at 3600 rpm and do if you try to use some pipes and different muffler you could run into back pressure problems and overheating the engine and damaging exhaust valve. As I see it you have 2 options,,, use inverter and run your vehicle or try to find and RV used generator which are quiet and run at 1600 to1800 RPM.
