Any way to buy 3m Trizact 5000 by the single sheet?
VAS
Hey I'm looking for 5" (or even 6") trizact 5000 grit sand paper by the single pack. I just want to try it before I shell out $85 for a box of paper I might end up having no use for. AG only has the 15 pack available. If anyone is willing to part with 1-3 disks I'll gladly pay $6 each + shipping. I don't know if that sort of thing is allowed on the forums, so please forgive me if it's not. Thanks!
Have you tried looking on fleabay? Sometimes they have smaller and larger quantities than what AG carries.
Your local auto parts store will sell single sheets. Check in the painting supply aisle.
We carry the #3000 Trizact in single packs but I don't see the #5000 on the store.
On Autogeek.net
3M Trizact 6 Inch 3000 Grit Performance Sanding Disc 01459 - Singles
We now have in stock the 3M Trizact 6" #3000 Grit Performance Sanding Disc in single packs from 3M for people that just need to do some spot sanding and don't need an entire box of discs. We also carry the 3" #3000 Grit Performance Sanding Discs for spot sanding minor imperfections of sanding thin panels or working in tight areas.
All three of these discs are for damsanding, that is they are designed to be used wet, not dry.
6 Inch 3M #3000 Grit Performance Sanding Disc
