Anyone combine ONR with another wash?
YankeeFan
I did this yesteday just to see if there was any difference. I put 1 1/2 capfuls of Optimum Wash with a capful of ONR. Thinking ONR is suppose to be very slick, so theortically it should help to reduce swirls. Seemed slicker but less sudsy. Anyway, does anyone do this on a regular basis?
Howard
I have heard of others mixing a little ONR with their regular wash shampoo. Seems it helps to minimize water spotting. I plan on trying some mixed with DP Xtreme Foam in the foam gun if it ever warms up around here.
:iagree: and did it all last summer. A capfull in each washbucket to act like a H2O softener.
Hi. I use a capful or 2 in every wash with my regular soap to stop water spots. Had a problem with that last year and I read here that it would help and it did. Never had the waterspot problem again. I've been using it ever since.
I've only done one water wash since I got ONR in the late fall, but I did add a capful to the mixture and it seemed to be more slick, which makes sense to me.
While ONR would help the lubricity of the wash, I would guess ONR would mute the suds from your foam gun. If anything, I would be tempted to put ONR in a spray bottle and mist the spray all over your car, then hit it with the foam gun.
Both buckets.....never thought of that.........will try next time......thanks.
No, that was sort of misleading, huh. I just put a capful in the wash bucket not the rinse bucket.
