anyone else impressed with yellow CCS spot buffs?
builthatch
i've found that the yellow spot buff and optimum compound is quite a powerful combination for DA scratch removal. it's fast and it's easy to gauge when you've removed JUST enough. obviously it will haze a bit so you have to refine after but regardless, it's amazing how it makes such quick work of moderate scratches. i find myself using my DA more and more vs. my makita, especially on softish clears, but on hard clears i'd always instantly reach for my makita if there was a major blemish. that isn't necessarily the case anymore.
from what i've read, the PFW react the same compared to what i'm experiencing. it removes the defect quickly and leaves hazing that needs to be refined. i've used these yellow spot buffs on an 01 360 ferrari and my own 08 mazdaspeed3 with a PPG refinished roof. it takes seconds to remove the defect using optimum compound, weight of the buffer and the little yellow pad. the hazing that is present is easily removed with a white or green pad and optimum polish. i address the major defects first, then go over the whole panel or car with white or green pads and the OP anyway, and then a final group of passes with a red pad and op OR a gray pad and poli-seal.
i'd buy a pfw to try but i don't see how i could have better results hehe
not real impressed with the yellow foam on the rotary. maybe with the DA, its different.
