HAMBO
- Jan 19, 2017
- 126
Hello all,
In our area you can get a pretty hefty fine for using a hose and 2BM to wash your car, so I have mostly been doing rinesless washes. I have a portable Foamer, so can produce some OK foam without using a hose. Was wondering whether anyone incorporates foam into their rinseless wash routine?
I have on occasion used the foamer I bought when I go to the local coin-op so as to use my own ph neutral foam (rather than their foam). I do a foam + pressure washer rinse, then go home and do a rinseless wash with ONR (with a layer of diluted ONR also spayed on as pre-treatment), but that's time consuming with the back and forth to the coin-op. I was wondering whether anyone else uses foam in this or some other way in a rinseless wash? Maybe as a pre-treatment before doing the rinseless wash (ie instead of using diluted ONR as pre treatment)?
Thanks!
HAMBO
Thanks!
HAMBO
