i just received my flex3401.. new user ..
i went to change out to the flex oem 4 3/8" backplate and immediately notice that the plate is off center.. about 3 3-5 centimeters.. this is estimate..did not measure.. i partially see the felt ring on one side about 2 millimeters of the felt ring is exposed..
after seeing this.. i removed the 4 .xx plate and reinstalled the stock plate.. that plate is off center as well.. same off center location as the 4 .xx" plate.
yes, both plates are seated correctly, i had to adjust the spindle to ensure the plate seated correctly.
is this normal or a defective unit..
doesn't seem right.. especially with part of the felt ring exposed??
anyone .. ?
anyone .. ?
