I can't address ownership issues, but in the hunt for my next vehicle I've driven several for extended periods of time. Here are my thoughts:
- I'd highly recommend the RWD over the AWD. The transmission in the RWD not only has more gears, but it's more responsive. Also the AWD model felt more nose heavy and not as tossable as the RWD
- Go F-Sport for the better ride/suspension, and fantastic seats
- The 200T and 300 are guttless wonders. I found driving them very frustrating due to the lack of power. An F-Sport IS350 would be the only trim I'd consider. It's not as quick as the horespower specs would lead you to expect due to throttle calibration and overall weight, but at least it will move if pushed hard enough.
- Spend some time working the interface for the entertainment system. The joystick is very strange and not well implemented (IMO). I'm not sure I'd like using it on a daily basis. Fortunately there are some speed buttons and in '17 models on (I think) the voice controls were expanded to do everthing including rasing/lowering the temp on the climate control.
- Material quality is pretty high except for a few of the plastic bits on center dash area.
- The interior is very quiet well past legal speeds
- In "Sport+" mode, it corners quite flat and is pretty fun to drive.
Depending on the desired price point you're shopping, it would be hard to beat. It won't perform like a RWD BMW 340, but it could be a very satisfying daily driver with the V6 and RWD.
