VISITOR
Active member
- May 10, 2007
- 9,859
- 3
anyone use either one or both of these products?
Lucas Oil Deep Clean Fuel System Cleaner
Lucas Deep Clean is blended with an exclusive Lucas additive package and specific carrier fluid that contains no diesel fuel, kerosene or anything else that can be harmful or useless to an engine. It also reduces NOx emissions, eliminates the need for higher octane fuel and deep cleans the entire fuel system and combustion chamber.
Key Benefits
● Greatly reduces harmful NOx emissions
● Removes carbon deposits
● Totally eliminates knocking and pinging
● Raises mpg and performance
Lucas Fuel Treatment
Lucas Fuel treatment complies with the federal low sulfur content requirements for use in diesel motor vehicles and nonroad, locomotive and marine diesel equipment engines.
A powerful blend of oils and additives that contain no SOLVENTS. Designed to increase power and fuel mileage and also lower exhaust emissions through a more complete combustion.
Lucas Fuel Treatment is formulated for both gasoline and diesel engines, carbureted or fuel injected. It gives your fuel system what it really needs - a blend of super slick oils and additives with a high detergent action that allows the engine to operate at maximum efficiency. Also, it cleans and lubricates the carburetor and injectors and causes the fuel to burn more thoroughly for increased power and less fuel consumption. Lucas Fuel Treatment should definitely be used in vehicles that require leaded fuel because it actually replaces the benefits of lead in gasoline without causing harmful emissions. Use it to pass smog tests. Finally, it totally neutralizes the harmful effects of low sulfur diesel fuel.
Key Benefits
● A great tune-up in a bottle
● Cleans and lubricates the fuel system
● Neutralizes low sulfur fuel problems
● Increases power and miles per gallon by burning excess exhaust emissions
● Increases the life of pumps and injectors
Key Benefits
Key Benefits
