It depends on the brand of APC you are using.
Most APCs and degreasers are both alkaline base / wheel cleaners are usually PH neutral or acidic.
It basically boils down to the PH of the product at the specific dilution ratio + specific surfactants in it and what you want to clean.
- Organic residue like petroleum oils/grease can be removed with alkaline.
- Mineral deposits (hard water), oxidation, insoluble oxides are best removed with acidic cleaners... also is MAY etch metal if the PH is too low (low number), so be careful.
0-1 PH = pure acid like HCL / battery acids
7 PH = water
12-14 PH = things like bleach / lye
I would check the MSDS sheet of the product to see what the PH level is and see what anyone else says about the product on the web.
I never use APC to chemically strip paint so I don't know what to tell you about that. I would prefer just to polish the paint. Polishing will remove everything plus remove defects plus make the paint look good.
As for tires? probably a 4:1 ratio? Most APCs on the market come with dilution recommendations.
Since IPA is not an APC; then specifically:One more question apc.
Can it destroy my paint?
For example I heard that IPA can damage
paint if it is left too long on paint.
