Applying Blackfire wet diamond
LeonPhelps
Hi guys and gals. New to the forum and have a quick question. If I apply Blackfire wet diamond tonight would it be ok to remove tomorrow night ? Dont want to rush the process. Also i just finished polishing and im wondering if this would be a good next step or if I should use something else first ?
Apply it and remove it after a few minutes. No need to let it sit overnight.
It should be OK to leave it on overnight. The key is that the cure time needs to be "moisture-free".
If dust settles on it, it could cause marring as you remove the excess sealant.
IMO complete waste to let it sit overnight, takes all of 5 minutes to apply and remove!
LMAO!! Get a good nights sleep!! IMO it may be a little more difficult to remove, however, you are talking about Blackfire products...IMO one of the best brands on the market...PERIOD!!
Just tell your ride you decided to leave her/he facial stuff on and will remove it the next day!!
I believe Midnight Sun is a WOWO wax so again, it may be more difficult to remove.
It is SOOOO easy to put on take off, you won't lose much sleep by wiping off right after you apply it.
Directions:
For best results clay the paint first with BLACKFIRE Poly Clay and polish with BLACKFIRE Gloss Enhancing Polish or BLACKFIRE SRC Finishing Polish.
Hand Application: Always use on a cool surface out of direct sunlight. Apply a quarter size amount of product on a dry applicator pad and wipe on the surface using small, circular motions. Allow Wet Diamond All Finish Paint Protection to dry before buffing. Buff haze with a clean Cobra microfiber towel.
Machine Application: Apply BLACKFIRE Wet Diamond All Finish Paint Protection using a finishing pad or wax pad on an orbital polisher, such as the FLEX XC 3401 VRG Orbital Polisher. Work on a small area, about 24 to 24 inches square, out of direct sunlight. Apply two 6 to 8 inch lines of All Finish Paint Protection directly onto the surface. With the machine off, spread the sealant over the surface using the dry foam pad. This coats the foam pad and the paint with sealant. Place the pad on the paint and turn the machine on. Set the speed dial on the polisher between 3 and 4. Work the pad over the surface in a back-and-forth motion and then an up-and-down motion. Apply until the sealant starts to dry. Cover one section of the vehicle at a time (i.e. the hood, a door, fender, etc.) Allow a haze to form. Hand buff to a brilliant shine with a Cobra Microfiber Towel.
Yes you can let it sit until 2023 if you would like.
Thanks guys I saw how easy it came off and took it off last night.
