Applying Jet Seal 109
Aingoi10207
39
So I just did a detail on my car over the weekend. I washed, clayed, polished, and waxed. My lsp was Mothers california gold synthetic liquid wax. Now today I purchased a kit from chemical guys that comes with a bottle of jetseal, and I want to apply it to my car when I receive the kit (should be a week or two). My question is, do I have to strip the lsp/clay again before I do so? Or can I go ahead and apply the jetseal after a wash? Thanks in advance for any feedback.
My understanding is you would want to apply sealant after polishing in order to bond properly to the paint.
I would at least go over the car with some type of paint cleaner to remove the Mothers Wax. You will probably run into bonding issues if you attempt to apply Jetseal over the Mothers.
That's what I thought. What's a good cleaner? I have a bottle of ultimate polish, would that suffice?
Just strip the old lsp off, no need to re clay or polish. I use CG Citrus wash in a higher concentrate but dawn or the like will work just fine.
If the paint does not have defects that you want to correct...save your clear coat and use a paint cleaner like Pinnacle Paintwork Cleansing Lotion will restore and preserve your car's original beauty.
AGO has lots to choose from:
Car Polish - Pre-Wax Cleaners & Paintwork Cleanser
Some have light abrasives and almost all have a chemical component designed to strip wax and sealants.
Opinions vary on whether these will actually strip a coating such as CQuartz, 22PLE, etc.
You are going to need to wash and strip off the current LSP before apply JetSeal 109.
What exactly does Chemical Guys recommend to wash and strip off the current LSP (Mothers California Gold Synthetic Liquid Wax)?
The correct method would be to sell/trade/return it and replace it with a better sealant like Duragloss 111 or Wolfgang Deep Gloss Paint Sealant.
Lol funny thing is I didn't actually buy the kit, I had a problem with a 3" backing plate I bought from them a couple weeks ago, so I called them up and they refunded me for the bp and are sending me the kit to compensate for their faulty product.
I use jetseal 109 as a sealant which I put when after using a glaze. The nice this is also applying to the windows and lights.
Sent from my SM-N900P using Tapatalk
I love how people say to return it...lulz. Jet Seal is a great sealant with awesome longevity. Strip Mothers then apply 2 thin coats of Jet Seal OP. You can then top with wax.
I'd agree. I've used, enjoyed and got good life out of the old version of JetSeal. The new version claims up to 12 month now, same $39 price point.
I've used Blacklight topped with JetSeal for a while. Hell of a combo.
I use it to apply it on windows, headlights, and backlights.
When I did my detail last weekend, it was my first time doing paint correction so it took me forever (nearly 9 hours) just to compound (using UC), and I was exhausted by the end of it and just wanted to finish up, so I skipped the ultimate polish step and went straight to waxing. Also because the car looked great (super glossy, 75% of swirls removed), so I didn't think the UP was necessary. But looking back, I think i rushed it a bit and should've gone ahead and followed up the UC with the UP just to get a few more swirls out and bring some more depth. Long story short, my plan is to wash with citrus wash n gloss (concentrated stronger for stripping), polish with the UP, and then top it off with two coats of the jetseal. What are your thoughts on this plan?
Klasse AIO is a nice paint cleaner or u can buy megs black wax for darker cars or megs white wax for lighter cars. That's good stuff!
No need to do a "Stripping Wash" in your case. Any compound or polish will effectively strip almost any LSP, definitely wax.
Citrus Wash & Gloss is not the same as CG Citrus Wash. The CGW&G leaves behind the "Gloss" component. This type of car wash may not be the best choice if you were applying an LSP that requires "naked" paint; such as Opti-Coat, CQuartz, etc. Chemical Guys does not specify and special steps prior to application other than the car be clean.
I have never tried Jet Seal 109, but I talked with a Pro Detailer at the Grand Opening of the new Chemical Guys location here in LA. He was buying 4 gallons of Jet Seal 109. Swears by it.
If it were me:
-Regular 2 Bucket Wash use your CG&G at regular dilution
-Baggie Test to see if Claying is required. Probably not, 2 weeks out from compounding.
-Test Spot w/ Megs Ultimate Polish and a White pad on speed #5 with a DA
Go from there depending on your level of satisfaction
-Apply Jet Seal 109 following CG's directions
Chemical Guys JetSeal 109 Super Acrylic Sealant Formula 16 oz.
If it were me:
Sweet, thanks for the advice!
