Applying Natty's Blue
JBs
can i use the PC to apply it? what pad should i use? or how else could i apply it (i don't think i have any applicator pads
You could apply it via PC but that isn't the designed application method. If you do go this route use the softest finishing pad you have. Or go to Wal MArt or any auto parts store and pick up some foam applicators or even MF applicators...
I've used NB on a pc and actually found it pretty easy. Easy to jiggle out of the container and rub in a couple times around a black pad and easily cover a couple of panels.
NB by PC is easy, I use a very soft 4" Edge Blue Polishing pad. I can do my truck in a fraction of the time it takes by hand and I seem to use less product, makes for a nice, thin, even coat. PC rocks for applying waxes if you have the right pad.
I agree Surfer, but did you see the poll? 70.5% by hand and only 29.5% by machine. It's so much easier by machine and twice as fast with great coverage. Wonder how many of those 70.5% have tried the pc?
Some said they just prefer by hand to "caress" their vehicles I guess, I could care less, when you have 6+ vehicles...I want it done as quickly as possible...suv's are a pain lol.
what if i only have a gray pad?
unless you have a super soft finishing pad you might as well just go to the store and pick up some foam or MF applicators.
I do it by PC as well. The wax easily comes out of the jar, and I only need a couple quick swipes across the pad and I'm good to go for an entire panel. My fingers hurt after a while doing it by hand, so I like the PC just for that reason alone.
