Shortspark
- Jun 14, 2012
- 671
I have an ML350 in Diamond White color (a beautiful but fairly expensive white option paint). My last detail had 845 as my LSP and after two or three washes I top with OCW. I have always "topped" by the usual method of WOWO using a microfiber towel.
Today I "topped" again but this time I applied OCW much as I would a liquid wax. I know it is not intended to be an LSP type of liquid wax/sealant but I get a lot of durability out of OCW because my ML is a garage queen for sure and is not in the elements very much at all.
What I did this time was use a stain applicator pad (the ones you buy at Harbor Freight for about three dollars an eight pack). I sprayed the pad and applied the OCW to half the car. It spread very thinly this way and I used only a few sprays on the pad once it was primed - much less product than my normal WOWO method. I then went back and buffed it off with my microfiber towels. OCW does not really haze (maybe it would if I left it on longer) but I think the benefit from this method comes from my actually rubbing in and working it into the paint much better with the stain pad, rather than just a WOWO kind of application.
Maybe there was no real difference but to my eyes I noticed a little more "candy apple" kind of gloss than I am use to seeing on this paint from OCW. With the normal WOWO method, I have always noticed a deeper, richer carnauba look that darkened the paint slightly, or I should say, deepened the pearl/diamond look, if you know what I'm getting at. This time it was not as deep but more sealant-like in appearance and reflection. Just the opposite of what I thought "rubbing it into the paint" would do.
Like I said, it could be my imagination and I have no explanation for it, but I think working the OCW into the paint first with an applicator made a difference in appearance over the regular WOWO method. I know it involves twice the work but I sort of like this look and will try it another time for sure. Has anyone else applied OCW this way? Has anyone even attempted to apply OCW by machine?
