:whs:P21S is one of the easiest waxes to use ... by hand. A lot of people use the foam material in the container as an applicator. Wipe the wax on with that applicator and wipe off. It goes on and off super easy. I have never been a fan of applying paste waxes with a PC because they are usually easier to do by hand, quicker and you can get into tight spots by hand.
Maybe I am retarded, but it is coming out in little chunks, and looks like candle wax. Brace do you pre wet your pad with a QD spray?
It's all right to apply with the blue pad, but not to remove. Use a mf to remove or a bonnet if you want to use a pc.Speaking of waxing by hand. Is it okay to apply the wax by hand, then remove with the edge blue finishing pad? I'm a newbie, i used my Milwaukee rotary for swirl removal and glaze application only. I applied the wax by hand and removed it by hand the first and only time i've waxed my car so far.
