I'm a machine guy too...
I really only like applying LSP's by machine, too many benefits when working by machine and too many drawbacks to work by hand...
Especially when working on anything large or anything you've put a lot of blood, sweat and tears into...
Behemoth Machine Sealed
The DP Poli-Coat Paint Sealant is a fairly thick product compared to other sealants...
After massaging the paint with this new sealant look out the sealant has spread out to cover the entire face of the pad, this happens with other machine applied paint care products too...
The sides were easy but the higher section required the use of the ladder and even a Skyjack Scissor Lift.
DoDo Banana Armour applied by machine,
The Microfiber Gloves keep the wax clean until you place it back into the jar and enable you to grip the wax so it doesn't slip out of your hand and onto the floor...
Ready to start laying down some Banana Armour...
It takes a little muscle to do this because in one hand you're holding the wax and the other hand is holding the polisher for the duration of time it takes to run the polisher over every square inch of the car. If you had a helper they could hold the wax with microfiber gloves on and you could use both hands to hold the polisher, then as you needed more wax your helper could apply the wax while you hold the polisher, otherwise
hit the gym.
If you look carefully you can see I spelled out Dodo on the hood in my wax pattern...
In the forum world you'll often read people talking about getting the
"Sun Shot" , that's where they pull their project car out into the sun to show there are no swirls in the paint.
The below shot is kind of like the "Sun Shot", but I call it the
"Fun Shot" because I was just having some fun with the Dodo name in wax.
I used a rubberband to hold a
Cobra Indigo Microfiber Bonnet over a
3" Griot's Garage Polishing Pad on a DA Polisher and took the wax off only where the word DODO was spelled out and then pulled the car into the sun for a "Fun Shot".
The Sun Shot Fun Shot
Dodge Magnum Machine Waxed...
1994 Porsche 964 Turbo 3.6 machine sealed with Wolfgang Deep Gloss Paint Sealant 3.0
1957 Chevy machine sealed with Wolfgang Deep Gloss Paint Sealant 3.0 using a Flex 3401
I always machine waxed the Milk Truck when I owned it... way too much real-estate to do it by hand...
1966 Milk Truck
Welcome to the machine...
