captainray
- Jul 27, 2012
- 17
For those of you who own, or are planning on owning an AR Blue Clean AR390 pressure washer, you might have run into the same dilema I did. There is no way to clearly tell what fitting to use when adapting the Autogeek Foam Cannon.
I searched the internet high and low, prior to purchasing the unit, for connection dimensions, or user photos to determine what fitting would fit the AR390's wand. By the way, the AR390 uses different connections than the AR383, or any of the other AR Blue Clean pressure washers.
Anyways, below are pictures of the AR390's wand, the connection type and the KRANZLE fitting that fits on the end of the wand.
Hope this helps
Hope this helps
