I put mine in the wash with my microfiber towels last time and seemed to put back some life into them...But yes they are definitely reusable!
Yes you can wash and reuse them but separate the applicator pads to a specific duty like paint, interior, exterior..etc.
The reason you want to keep them separated like that is to prevent contamination. No matter how much you wash the applicators you will never remove all the residue in them.
An applicator used for Black Wow should not be used with other products on the paint. It should be dedicated to that product only. Most all others can be cleaned & reused.
I wash mine just like the buffing pads I use and they come out great but keep in mind what you've used them for. If they're greasy or contaminated with something other than what you normally use detailing then I would ditch them otherwise wash and reuse.
I find it better to dedicate an applicator to a specific product and store it in a labeled zip lock bag. I like the durafoam ovals that go for $8-9 each and prefer to dedicate rather than wash and re-use. Just my $.02Hi everyone,
Do you guys wash your foam applicator pads after using it? Can you use different products with it after washing it? For example if I use black wow with it on trim and then wash it, can I use it for some other chemical?
Thanks!
