Ash marks on headliner
Dirtyaintpurty
I've got an issue with cigarette ash marks on the headliner on a 2012 dodge journey. What can I use to clean up these marks, they're also on the visor, the visor hard material though. By the way, I'm not the one that left the ash marks or smokes even.
I cleaned my whole cabin's headliner not that long ago using Chemical Guys Nonsense as a spot treater at a 6:1 dilution with no problems. Dab the stain and lightly agitate, let it soak for a couple minutes, dab again with fresh water. Repeat until stain is removed. Worked for me.....
I'm guessing this is a fabric headliner...try GENTLY with an "art gum eraser."
Bill
Folex!! and some microfiber
Like any liquid based products (on the headliner), use sparingly and do not allow to soak too long for fear of messing the adhesive.
I take my MF fold it 4 ways, Spray some APC (all purpose cleaner) on the towel and blot the area. I then have a smaller horse hair style tooth brush and I lightly agitate but do no rub because then your just smearing it around. Blotting is key here.
If it still appears wet I will run the shop vac over it but in almost all cases I have come across personally just blotting works fine.
Folex, MF and the Tornador Black. I use Simple Green diluted in it. Works great every time.
