Thanks mate.....Super job Pampos... you are the UDM guru. Have you looked into the new Griot or Meg's G110v2. These newer DA's should save you a lot of time. I know you are a pro and can use a rotary, but you get some awesome results with the UDM. Just thought that the newer DA's will cut your time. But like they say, don't fix what's not broken.
Yes, much more than the first generation PC, G110 and Griot. I have the new Griot and it's a work horse. You can run 6.5" pads put all the pressure you want on it and you won't stop it from rotating. It comes with a lifetime warantee that Auto Geek honors and for $129 bucks. The new Meg's G110v2 also has gotten great reviews. These new DA's are very close to the Flex DA in terms of power. They are not forced rotation so the Flex is still king among DA's, but for 1/3 the cost you can't go wrong.Thanks mate.....
thanks for the info about the new DA's polishers...I have a rotary but i am not using it very often so a better DA polisher will be the best for me....
Are they more powerful???
Thanks very much mate...i will buy one soon :dblthumb2:Yes, much more than the first generation PC, G110 and Griot. I have the new Griot and it's a work horse. You can run 6.5" pads put all the pressure you want on it and you won't stop it from rotating. It comes with a lifetime warantee that Auto Geek honors and for $129 bucks. The new Meg's G110v2 also has gotten great reviews. These new DA's are very close to the Flex DA in terms of power. They are not forced rotation so the Flex is still king among DA's, but for 1/3 the cost you can't go wrong.
