•Which paint-system...Any one know what the average paint thickness is for a new car? Also what measurement is used?
Thanks.
Again:I am looking for the average thickness for a two stage paint job.
Im looking for mostly asian and american cars.
My 2014 Mazda 3 has 55-80 microns depending on where I take the reading. My hood and doors are around 70. The trunk is 55, while the thicker panels on the lowest part of the car are 80.
That's some scary thin readings. Paint cleaners only, no compounds on those readings.
Ok, if I take my car to a detailer for some paint correction. How will they know how agressive they can be without taking the clear coat down to far? For example you generally do not want to remove more than 25% of your clear coat over the life time of the car. Otherwise you risk clear coat failure. So if each manufacture is that different this can make it difficult to judge?
Thank you
I agree, I checked others at the dealership, all the same readings. I have read another thread saying Mazda has the lowest they have ever seen. I'm not sure why they have such low readings.
Thin paint equals more bottom line.rops:
Maybe it's for weight reduction :laughing:
Makes me wonder about my 08 Mazda3
I would ask the detailer if I could take a look at theirOk, if I take my car to a detailer for some paint correction. How will they know how agressive they can be without taking the clear coat down to far?
See...You already know what some people fail toFor example you generally do not want to remove more than 25% of your clear coat over the life time of the car. Otherwise you risk clear coat failure. So if each manufacture is that different this can make it difficult to judge?
Links to sources...TIA.The industry average for clear is 2.0/2.5 mils.
The paint gauges that do each layer have
been proven to be not accurate at all.
Can you guys recommend a inexpensive tool for measuring paint thickness? I am just a hobbyist and I would rather play it safe.
Thanks
Sent from my HTC M9
