What kind of car do you have some paint is very soft. What towels are you using. I have had jet black bmws, black Honda and Subaru paint exhibit this trait. The only way to combat is with super soft towels and a light touch. It can really be frustrating and increase the length of time the job can take.
I got a jet black bmw and the paint is extremely soft. I tried many micro fiber including those ultra soft and thick 600 GSM and still got micro marring. I dried the car with waffle weave using 0 pressure still got no luck.
im sure i was swirl free before the gtechnig cos i just repolished the car with 0 pressure using 4000 with black pad. A tiny pressure on the pad would cause micro marring.
If you mean Menzerna 4000, it's very oily and might hide the marring it is leaving behind. Are you doing any kind of panel wipe prior to using the coating? Woobie Microfiber Towel, 3-Pack, buffing towel, edgeless polishing cloth These are my go to for super soft paint. As little pressure as possible.
As far as drying the car, forced air is your best bet, if not, lay the waffle weave towel across the paint and blot it dry, don't move the towel over the paint all. Finish with detail spray and a really plush microfiber, wiping lightly.
^^ this. It's the same with my Audi.
Key tips:
Blot dry with high quality MF/waffle weave
Never use the cheap MF towels. You know the ones that stick and pull on dry hands.
When removing Polish or sealants it's with only 480 GSM or better MF rags and with a very very light movement.
Never Polish or buff even a freshly sealed car with a dry MF towel. It's often enjoyable to go back and really do so admiring your efforts and the paint but do it and you'll get micro marring.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Which gtechniq coating are you using?
What year BMW?
I would switch to Essence and avoid the IPA/Panel wipe down all together on paint this soft
1. Can you go directly from polish to coating with Essence (after wiping the excess away, of course)?
2. Has it been tested (or have others have good experience) when used with non-CarPro coatings?
To the OP: one question to ask yourself is if you are using too much C1 and/or EXO. These products can be applied very sparingly and in my experience with them, gentle buffing with a towel (I use the Gtechniq branded towels, which are only about 300 GSM -- MAX I bet) without micromarring. I think the key here is light application and gentle buffing, notwithstanding all the other great advice before me.
