Backfire interior cleaner
BLKONBLKONBLK
I picked up some blackfire interior cleaner on my last order, went to use it today and it would not even spray. It completely clogged the sprayer
Has anyone else had this issue? Did I just get a bad batch?
is it the cleaner or protectant? I had the issue with 2 bottles of protectant. I just pour it out on a mf pad now.
Are you sure? If I'm not mistaken, I believe the tips of those sprayers are adjustable, meaning you can set it to spray, stream, or off. They are typically in the off position when shipped. What was your sprayer set on?
I was going to give him the benefit of the doubt that it was on the spray position:props:
But mine yea only a little will spray out at a time.
Yeah it's on on both spray and stream I get a short burst of about a half a trigger pull and then nothing
Had that problem on a sprayer from poorboys. Make sure the spray handle is making proper contact with the plunger. If it is,, and you still dont have full spray, force the handle (doesnt take much) ALL the way forward. If you hear a pop and it starts to work you've seated (i think) the handle better. You should only have to do this once in awhile. Otherwise Id try to get your money back.
