Before I Use My Flex
Not really but the early ones had a felt washer under the backing plate that needed to be lubed using house whole oil like 3in1 oil.I would do that even if it isn't needed.Just a couple of drops
i just got the 603 rotary not familiar with 3401 mine didn't come with a backing plate. i'm using the edge 2000 pads so no plate required, but the pc i have does motorcity is right make sure its tight
lube felt ring and check the backing plate, thats it.
Ditto on Wystangs sound advice. Although when we got ours the top handle snapped off, and it works pretty darn good. So we would add, snapped that handle off.
under the backing plate .... remember to tighten the bolt with the included hex wrench.
Thanks! I did that & then polished out my girlfriends headlights with some PB SSR products. They came out great! That was my first time using any type of polisher.
Just to get your relationship with your FLEX off to a good start you might try dinner and a movie. Nothing over speed 4 on the first outing!
