Hey guys,
1st time cleaning wheels and am having trouble getting the remaining 'black substance' off the backside/inside of the wheel section.
They're off a 2004 HONDA CRV. The inside.. I don't think is clear coated.. at least it doesn't feel like it. There's a groove type pattern going around, so I think it may just be machined alloy??
The outside of the wheel, however, does appear to be coated and not as bad.
After hitting them with Wheely Clean (similar to Iron-X), they were quite spotted (see in pic). As the wheel appeared quite bad, I used some oven cleaner.. which helped a fair bit. I then decided to use a 50/50 mix of Hydrochloric Acid, which certainly helped.. but behind the spokes, remains black spots.. which I cant seem to remove, even with oven cleaner and/or 50/50 HCL... ideas ?
I'm hesitant to use a stronger mix of HCL, but has anyone used strong acids on alloy rims before?
Before Cleaning
~~ After using Bowdens' Own: Wheely Clean ~~
>> It cleaned minimal, leaving it spotted. Looks like its really backed on.
~~ Used some Oven Cleaner ~~
Alot better, but even with scrubbing, I couldn't remove the back behind the spokes.
~~ After Using a 50% mixture of Hydrochloric Acid/water ~~
As you can see.. a lot better, but still can't get it great.. ideas?
Thanks in advance
Before Cleaning
Thanks in advance
