Just4Fun20
- Nov 5, 2020
- 4
I did considerable research (Google Searches) and finally went with what seems to be a traditional approach to remove orange peel (from a repair, Sikkens paint, Sikkens 2 part CC - two coats). As you can probably tell I'm a weekend warrior. I've been fixing cars, as a hobby, for years but body work has always eluded me. I've tried, but... I'm gaining and my repair looks pretty good but the final mile is being difficult. "Buffing it out" or "color sanding". Here is the process I used:
1) Wet sand 1500 (or 2000)
2) DA - Orange Sponge Pad - Maguiars 105 Ultra Cut
3) polishing compound (haven't gotten here yet).
I was not satisfied with the results (in my reasonably small test area). I know it's an art form and seems to take a lot of practice. I think my failure was that I didn't sand enough. The videos I've seen here discuss making sure there is a smooth, consistent "buffed" area (IE, no peaks and valleys). That said...
When I wasn't satisfied I dug deeper and found these forums. Excellent. Thank you. I'll keep digging but, honestly the amount of information is staggering and complex. In today's world there seems to be significant movement away from wet sanding (step 1) and towards using a DA with "denim" or similar pad. This is where I'm confused.
What compound is used with the "denim" (or similar backing plate)? Would the 105-Ultra Cut work or is that still Step 2? If it won't work is 105-Ultra Cut still a suitable Step 2?
As much as possible I'd like to build on what I've already purchased but if that's not the right answer I'll do what I have to do.
Thank you in advance. I apologize for questions which I know have been asked and answered but I've seen many conflicting answers and don't have the knowledge base to sort one out from another.
