Best coating for looks and marring resistance
Coatingsarecrack
I know marring resistance is debatable on a coating so my question is which one is most visual appealing.
The car is a garage queen so it should see little to no rain so water behavior is a moot point and it will be cleaned whenever i take here out so even self cleaning not as important.
I like the look of a coating and the durability. I know wax may look better but not looking to go that or sealant/sio2 spray route.
Recommendations?
I have only used Dp once and Csl+Exo a handful of times. I will say I like the look of Csl as a stand alone. However, since I am going for durability I go with Exo combo.
•Just curious:
-What happened to the Coatings that
you previously decided upon to use
on the GQ and another vehicle; or ones
previously used and highly recommend?
Decided on NV Nova Evo for coating
on my summit white. Kamikaze was
a close second…
Will probably use Kamikaze
or CSL on my Chevelle.
Lastly CQUK3 is an amazing coating.
Used it on my last car and highly recommend.
:confused:
•Just curious:
:confused:
It was on my mustang which got totaled. I would have no qualms using again as i can’t see expecting better results.
I chose the Nova coating due to it only needing one layer. Plus still have the itch to try new things.
Edit: Nova is for my daily driver. Just rethinking that on the chevelle, won’t see much environment but sunny days so not looking for the traditional benefits of a Coating
Imo wax/sealants don't look near as good as a coating.
I would go with Kamikaze Zipang which is self healing with light marring. It's just a amazing coating.
CarPro SiC. Two layers and it will look like wet ice. Super easy to use too.
Sent from my SM-G988U using Tapatalk
^^^Sic is nice. I just ordered some 22ple Insanity per recommendation from The Guz.
My usual go to’s are UK3.0 and Miyabi. I think Miyabi looks a little nicer but I use UK 8 out of 10 jobs.
Lots of great recommendations. Some I've not yet tried, but really want to.
My only comment is not to focus on marring resistance. I highly doubt any coating will provide any marring resistance. However, other properties of those coatings make them much easier to wash/dry which allows you to adjust your methods in a way which makes any marring less likely.
Miyabi and insanity are in the running. Let me know what you think of insanity.
