A good and Powerful LED Flashlight, generally equipped with 18650 Batteries (please, I'll not enter in battery safeties subject like getting quality batteries, protected if needed, etc!)...
Not saying they are the best light (like you're asking), but definitively one cheap and handy tool, must have. Take a look at the Flex Swirl Finder Light, they are similar.
FLEX Swirl Finder Light
You won't hold the light too close to the paint (but some situations you can!, find the best distance testing various),
you'll try to 'incide the light directly' to the paint and spot the defects around the light, avoid looking into the light spot. You try enough until getting practice in doing this.
Like this:
Before (Inspection with Recommended Light and white paint):
Test Spot Preparation:
Test Spot Results (Inspection with Recommended Light and white paint):
Going for 'ignorance'! hehehe
*Pics Taken from my thread
http://www.autogeekonline.net/forum...-correction-coating-pinnacle-black-label.html
Hope that helps,
Kind Regards.
Thank you very much , I think I'll order from Autogeek that one.
WOW , what a awesome job you do , that is really impressive !!!! That's probably takes a lot of years doing it. I used to do boat detailing , 8 years ago, it's a hell of a job, back then there wasn't that huge product choice available. And the quality is improved a lot since that time.
Just made huge order from Autogeek LOL, I think I am set for a long time
I might order some stuff what I don't need right now or the pads who does the same only different brands, but I went a little crazy
Just want to keep my car in shape as it brand new
Here are the list
COBRA-WW1627-3 - 3 Qty Waffle Weave Microfiber Glass T 24.99
5 EIN-921008 - 8 oz. 1Z Einszett Kristall Klar Washer Fl 44.95
1 CP-5711 - 2 Qty 5 Inch CarPro Rayon Glass Polishing Pa 9.99
1 GG-2PACK - 2 Qty Grit Guard Insert- Your Choice! 17.99
1 PC7424-PAD-C-2 - Porter Cable Intro Pad Kit- Choose Yo 204.99
(HD)
1 LC-43-125DA - 5 Inch D.A. Hook & Loop Flexible Backing 17.99
1 LC-43-073DA - 3 Inch Dual Action Flexible Backing Plat 12.99
1 LC-WSH - 5 Qty Lake Country Compression Washers 4.99
1 XMT-PCC - Pinnacle XMT Pad Care Combo 19.99
2 W-9006 - 6.5 Inch Meguiar's Beige Soft Buff Foam Finis 25.00
2 W-8006 - 6.5 Inch Meguiar's Yellow Soft Buff Foam Poli 25.00
1 W-7006 - 6.5 Inch Meguiar's Burgundy Soft Buff Foam Cu 12.50
1 LC-46-230DA - D.A Adapter 5/8 Inch X 11 4.99
3 LC-58-42425 - 4 Inch Lake Country Foamed Wool Buffing 15.00
3 LC-58-4235 - 3.5 Inch Lake Country Foamed Wool Buffing 12.99
1 BONNET-KIT - Dual Action Microfiber Bonnet Kit 39.99
1 LC-3-COMBO - Lake Country 3 Inch Flat Pads 6 Pack- You 19.99
1 DP-7200 - Detailer's Detailing Clay & Lube Special 24.99
1 DP-75Q - Detailer's Quart Foamaster Foam Gun 59.99
1 DP-800 - 32 oz. Detailer's Xtreme Foam Formula Auto Sh 19.99
1 FBK-810 - Forever Black Tire Gel Kit 14.99
1 FLEX-993100 - FLEX Swirl Finder Light 39.99
1 COBRA-36-915-3 - 3 Qty 6.5 Inch Cobra Cross Groove Whi 29.99
1 COBRA-36-940-3 - 3 Qty 6.5 Inch Cobra Cross Groove Blu 29.99
1 COBRA-36-960-3 - 3 Qty 6.5 Inch Cobra Cross Groove Red 29.99
1 HNBK-PBL - Pinnacle BLACK LABEL Handbook 0.00
2 PBL-151 - 32 oz. Pinnacle Black Label Surface Cleansin 159.98
1 COBRA-1624WW-6 - 6 Qty 16x24 Inch The Guzzler Waffle W 69.99
1 PIN-621 - 64 oz. Pinnacle Micro Rejuvenator 39.99
2 COBRA-600JR - 16x16 Inch Super Plush Junior Microfiber 15.98
2 COBRA-600DLX - 16x24 Inch Super Plush Deluxe Microfibe 25.98
3 MF-700 - Microfiber All Purpose & Wheel Detailing Towe 17.97
1 PC-DVD - How to Properly Use the Porter Cable 7424XP D 12.99
1 DIA-301 - 3 oz. Diamondite Glasswork Cleansing Clay 14.99
1 DIA-302-2 - 2 Qty 4 oz. Diamondite Glasswork Clay Lubr 12.99
1 LC-99-COATING - 2 Qty Lake Country Coating Applicator 7.99
1 PBL-901 - 32 oz. Pinnacle Black Label Diamond Coating 59.99
2 5G-CLEAR - 5 Gallon Wash Bucket - CLEAR 25.98
1 DSM-3000 - Speed Master Wheel Brush Bundle 39.99
1 OPT-1200 - 32 oz. Optimum Opti-Bond Tire Gel 15.99
1 B-54223 - Recessed Wheel Lug Nut Cleaning & Polishing 11.99
1 G-81-207 - Fire Hose Nozzle 19.99
1 DP-710 - 8 oz. Detailer's Wheel Glaze 22.99
1 PBL-400 - 8 oz. Pinnacle Black Label Diamond Surface C 129.99
1 PBL-751 - 32 oz. Pinnacle Black Label Diamond Coating 79.99
Now I can do a lot of things
Thanks for your suggestion.
Sent from my
using Tapatalk
