Iron X snow foam soap would work pretty well for your purposes.
Are you not planning on claying the car before correction ?
If you going to be doing a correction then just wash and clay will be fine. When you go through polishing and or compounding you will be removing and sealant or wax.
You will be doing an aggressive wash method so the goal is make the surface as clean and debris free as possible.
Well since your not doing any polishing Im going to give you this thread to read through about stripping wax or sealants. There is a lot of great info about what works and what doesn't
http://www.autogeekonline.net/forum...096-possible-chemically-strip-sealants-2.html
Prep Wash Product (PWP) for removing pre-correction wax/ sealers?Need some input on which prep wash product is best suited
to remove wax / sealers before correction.
