Best Pressure Pump Bottle for Waterless Wash
I like the Kwazar Pump Pressure Spray Bottles. Autogeek has the wrong Sprayer on the product. The Black should be the Red one and the same with the Red should be the Black. Maybe email them first to be totaly certain which is what.
I would recommend the Kwazar Venus Super Compression Sprayer Pro which is the red one. It's designed to be used with acidic products and most WW can be on that side of the ph level. The Black one without the Pro in it's name is designed to be used with strong solvents. AGO does not have them but there are a light blue like these sprayers that are for the generic uses as the color the Kwazar Foamer has. Then they have a dark blue one that are designed to be used with strong alkaline based products. The red one will work great with a WW. It's real high quality if you use the right kind of chemicals in them. If you use let's say a strong alkaline APC in the red one the seals will be breaking on you.
/ Tony
... Not entirely sure if this is allowed but because Autogeek sell some Würth products I guess it’s okay. Würth do a very good pump sprayer that’s dead reliable & lasts ages. That’s my go to & has been for many years. :props:
Aaryn NZ. :dblthumb2:
