CarPro Dlux would be my recommendation.:xyxthumbs:
Aaryn NZ.
Has the 2014 MY trim beenI need help with keeping my black trim
on 2014 rav4.
Ultima Tire & Trim Guard Plus is well-reviewed, but I'm guessing it's better to apply it thinly, too. I applied about five heavy coats to my father-in-law's new running boards on his new GMC Canyon and it left those running boards super-slippery. It's been on a 500-mile road trip and washed twice since application, and those running boards are still slippery.
Dlux probably is the most professional choice.
So a selant like power lock won't leave the trim white ?
Sent from my LGMS631 using Tapatalk
No. Any quality sealant or wax will not stain trims. Power Lock is a good example. Reload doesn't either. The documentation for the LSP should say if it is trim safe or not. If it doesn't mention if it is safe on trim, assume it is not until you do a test spot.
I put menzerna powerlock on my 2015 mustang black trim, looks awesome, natural, no white stains or residue. I did the same thing a few years ago on another vehicle with turtle wax ice sealant. Worked much better than regular trim protectants that are water based. Most of those need reapplying all the time, not so with the sealantNtsHave you tried using Power lock? I love using reload on all rubber and vinyl trim but I've heard a ton of people say power lock doesn't stain while a few have said it does. It doesn't say anything so I haven't been brave enough to try it but if you or anyone else could help me settle this I would really appreciate it. Thanks!
replaced with new trim?
If not, then:
-Being that the trim would be
close to three MYs old; and,
not knowing what all it's been
exposed to during those years;
-I'll suggest the following
two-prong approach:
1.) An application of Solution Finish (SF)
(which includes a thorough cleaning beforehand)
2.) Then, after the SF has had time
to totally cure, apply Ultima
Paint Guard Plus over top of it,
as a "sealer" for the SF.
Solution Finish Black Plastic & Vinyl Restorer, trim restorer, black plastic restorer
Ultima Paint Guard Plus 4oz., paint sealant, liquid wax, car wax, paint sealer
what about WETS?
