bullitt1939
- Feb 29, 2016
- 18
I live in north Louisiana and it is very humid here. I am looking for the best way to protect and preserve chrome. I have heard putting wax on top once it is polished helps, but I have not tired this.
It is mainly for our show cars we have a lot of chrome under the hood.I often use just a spray wax on chrome like on chrome wheels after a wash. It seems to last more than one would think and makes cleaning them easier.
What products have you tried and does this polish and protect?Collinite products work good.The key is to keep on top of it being in humid environment.
Deosnt polish but protects pretty good.you probably can just get by with a cleaner wax or check out mothers they have that sector covered.If the chrome is like new I would just apply collinite.I use oooo fine steel wool with glass cleaner to get the humidity crud or grime off then apply collinite .What products have you tried and does this polish and protect?
If the chrome isn't in bad shape,you might be able to use Fleetwax on it. The metal wax works to remove light rust and other stuff but it is lightly abrasive. Fleetwax also hold up longer. We use Fleetwax on the polished stainless on the motor yacht I work on. We apply a heavy coat and don't remove it for deliveries of 3 days or more and then wax it off after arrival. It really protects the metal from the salt spray during rough transits and then for several months after we remove it. We also have the Insulator wax on board but I have the crew use Fleetwax because it holds up longer. It is a multi use product.
I skimmed through some of the posts here and I just wanted to clear a few things up.
1) polish is not a sealant or wax of any kind. Unless on the bottle it states it is an AIO type of product then there is no sealing properties. Polishing refers to correcting.
2) do NOT utilize carnauba waxes on wheels or anywhere where brake dust is prevalent. Why? Because the properties of that organic material actually attract and help cause the brake dust to clump and stick to the surface especially when water is added to the mix. It is even more noticeable when using cerametallic type pads.
3)Best longest lasting sealant to use on anything these days is a quality ceramic coating and doing a multi-layered process. Now nothing protects it against extremely hot brake dust from high speed braking. But it is the best most durable coating for chrome surfaces and pretty much any surface for that matter.
As for polishes there are many different polishes to chose from. Pick something that you like that works for you and your application.
I sure do not agree with # 2. I have/still use Collinite 845,476,885 etc. and the wheels stay cleaner than using nothing at all. What little dust I get cleans off very easily. Some people like coatings but I would not use it on chrome myself. Just my opinion.
Dave
