After QD, I'll apply spray sealant to car...either Chemical Guys V7 Optical Select High Gloss Spray Sealant Detailer or BLACKFIRE Deep Gloss Spray Sealant, spray wax, paint sealant spray.
The problem with applying a spray sealant over a just QD paint, is that the sealant will bond to the QD which will wash away quickly. If you must use a drying aid, use the same spray sealant when dry. Most spray sealants will work as a drying aid.
QD on black/And Low grade MF towels (I have switched back to 100% white Cotton and Zaino Border free blondes) = swirls.
When I had black cars, I used Optimum No Rinse diluted to Quick Detailer strength for touching up lower panels that see the most dirt. I would then finish off with a nice QD like Meguiars Gold Class , Chemical Guys Speed Wipe, CG Hybrod V07. Just use nice plush towels and apply no real pressure. Contrary to previous posts, you can use QD on black. It's all about technique.
