CAdetailer
- Jul 4, 2012
- 22
Setting up a larger DI system to make it easier to deal with my 550 ppm well water and very little shade on a dirt lot in the 2nd hottest spot in America.
Who has the best quality and cheapest VIRGIN mixed bed DI resin?
I need 0.75 to 1.0 cuft, or about 45-50 lbs. Amazon has some cheap stuff but reviews say it didn't work so I'm assuming it's " regenerated" but not done correctly, so that's out.
Best quality I've found is Dirinse.com. (1cuft for $230).
Servapure.com has it for $210 for 1 cuft
Windowwasher.com has it for $210 for 1 cuft
Portablewaterdi has it for $210 but not sure if it's a full 1 cuft
Even with a dual cartridge 10 mic carbon & 5 mic sedimant filter it only gets down to 415-425 ppm so I'll probably be going through a decent amount of resin and " regenerating" 50 lbs probably won't be happening due to the amount of chemicals required. So I'd like to find a cheap source of good cheap virgin resin.
I've also heard about fine resin for harder water but haven't seen any for DI applications, anybody know if they even make it for DI and who has it?
Thanks
Thanks
