Best sprayer for ONR?
getgoing
Hi guys,
Can someone please help me with three questions:
1. If I go to the Amazon page for Chemical guys sprayer, Robot Check, I see two products: "Mister + Sprayer" and "Sprayer Only"
What's the difference between them?
2. How does the Chemical guys sprayer compare to the older iK MULTI 1.5 or the newer iK MULTI Pro 2?
3. What is the best sprayer for pre-soaking with ONR (Optimum No Rinse)?
I'd be thankful for any guidance.
Does it have to be a fancy detailer sprayer?
I have been using a 1 gallon bleach sprayer, $20, for the last 5 years for my ONR presoak.
No anything that works is fine. Do you have an Amazon/online link for your 1 gallon sprayer please.
Thanks.
This will get you going.
Lube the orings with silicone grease or plumbers grease.
No link because rules.... but a copy/paste for Amazon.
Chapin International 20075 Disinfectant Bleach Sprayer
Hi, thanks. On the Chapin 1 gallon, how many times would I need to pump to use the full gallon?
Any thoughts on these smaller ones:
Robot Check
Robot Check
"Beaugreen 3 Litre White Garden Water Sprayer"
"Flesser 3 Liters Pump Pressure Sprayer"
Thanks.
Well geesh, that is a darn good question.
When I do a rinseless, I hit auto pilot and just start pumping it when the pressure dwindles.
I generally will use the whole gallon or very close to it. Overkill maybe, but better to be safe than sorry.
I also hit the wheels and wheel wells.
One of those smaller bottles would be fine to mist the loose dirt into suspension. I like to pretreat so it runs off the car.
