Best synthetic clay option?
Temple90
I would like some opinions on the different options out there.
I am leaning towards the CarPro Poly Shave Decon Towel or the Griots Surface Prep Pad.
I will be working on a 2007 satin white pearl Subaru Wrx Sti. The car is heavily contaminated even after Iron X treatment. Traditional Clay is taking too long per panel.
My question is how aggressive is the CarPro Poly Shave? I am worried it will not be aggressive enough to get the contaminants out of the paint.
All opinions welcomed.
Thanks!
I can't comment on the heavily contaminated paint, as I'm just a hobbyist.
But I have the nanoskin sponges which work great, the clay mitt for larger areas, also works great. Just ordered the Griot's Brilliant Finish synthetic clay sponge as well, which I have yet to try.
Thanks for the response. The paint isn't too heavily contaminated, but it is definitely too contaminated for a fine clay if that makes sense. I think a medium clay would tackle all of the contaminants.
I have the griots fine prep mitt and have had it for over a year its so much faster than clay and I have done the plastic bag test and always came out smooth. In its defense I haven't used it on a really bad vehicle so far
Sent from my PH-1 using Autogeekonline mobile app
Since I only take care of our two cars I started using the Nanoskin sponges a couple of years ago and they have worked out great. Using UWW+ mixed at the waterless wash dilution as a lubricant I'm able to clay without introducing marring. Here's a link to both sponges, but you can also buy them individually.
Nanoskin Autoscrub Speedy Prep Sponge Combo Pack
I have tried a few things over the years and I keep coming back to NanoSkin sponges. I think they work very well and are nice to use, especially if you do rinseless washes. Just drop them in the wash solution bucket. Clean your panel then grab the sponge and clay it before you dry. Much faster than any other process I know.
I also tried Optimum's clay towel and I hate it. It' s very hard to use because you have nothing to grab on, the only way I could make it work was to grab one edge and lift it. But when you push in the other direction the towel tends to fold on itself. Bleh! Also after claying a single car it is not covered in contaminants I cannot clean off. It comes as a while clay like substance, now it's half black and I am very hesitant to use it on an other vehicle. 28$ for a single car... what a waste of money!
are the nanoskin and prep mit basically the same technology? I've read both links and don't really understand how they accomplish the same results as a clay bar. And if they do, why the heck anyone would still use clay.
There are instances were clay alternatives cannot remove some contaminants and clay will. But otherwise, in 95% of cases, clay alternatives are faster, easier and less expensive to use. Plus if you drop them you did not just throw away 20$ like a clay bar.
The only thing you have to be careful about with clay alternatives is that they are extremelly heat sensitive.
- So you don't want to use them on hot panels or they may leave clay material behind on the panel and it's hard to remove
- They will stick to anything they come in contact with during storage, so you have to be careful how you store them. I have wasted many NanoSkin sponges by them sticking to something during transport in my truck. Now what I do is I put a piece of parchment paper (stuff for cooking) around them before putting them back in their plastic case. I also no longer leave them in the truck, I bring them inside when I get home. So far I have not had any more problem since doing that.
I've got the same mitt. I also have the pads for my DA's in 4" and 6". Also have the 6" medium. They work great.
If you spray the face of the towel with something like power clean it’ll clean up to basically brand new.
I have the sponges, and I hit them with a spray of power clean after every use and agitating it around with my finger I can see the gunk coming off.
I assume any APC/degreaser would work the same.
Thank you, I will give it a try. It look really embedded in there but if it can remove even a little bit of the gunk, I will be happy. Will also try it on the sponges ;)
If you have a large area (whole car) and heavy contamination, look no further than a clay pad on a DA.
Blue Nanoskin Wash Mitt. IMO all you need. I have been using mine for over 2 years and it still clays fine. Just make sure you store it properly.
Good advice! I've just started using my Nanoskin fine mitt. I noticed it was a little stuck to the packaging when I first got it. After I used it, I let it dry out then put it back in the plastic box, but I'll try the parchment.
I just got this mitt too. What do you mean by storing it properly?
I never thought of parchment paper either I have had my griots stuck to its own case but got lucky and it came apart without any problems but mine is starting to show some wear and tear. Anyone with any suggestions on whether I should get another griots or go with a different company.
