Mike Connors
- Feb 26, 2016
- 11
I have a 2017 Honda Ridgeline and am trying to keep lots of plastic trim look like new.
I don't like it to look real shinny.
Whatever trim protectant you decide to use, clean it well. Do an IPA wipe down after cleaning. Mothers makes a great trim cleaner...skip their sealant.My truck is extremely well taken care of but I used "Mothers" and I have used other OTC products that are either to shinny or they soon leave a greying look. I appreciate your response.
I like to use the Blackfire Tire & Trim Sealant on exterior plastic trim. Works great!
BLACKFIRE Tire & Trim Sealant, plastic trim restorer, tire coating, long lasting tire shine
I have a bottle of this and also Wolfgang (WETS) between the two I find the application better with Bobby B.'s suggestion. WETS was my first dedicated product and it is working great, but I used a cheap foam brush and just throw them away after each application. I'm cheap and try to rinse them out but the WETS carrier agent is oily to the touch and does not rinse out with water. However that is a good thing for trim!
BF Tire and Trim is my go-to for family and keep the WETS for my personal cars.
Key to using anything ( 'The Guy' recommends the best selection) is to do this on a regular basis. Do it every two to three months or as needed depending upon your factors. Using as preventive measures will give you the results you speak of and keep that Ridgeline a beauty!
I appeciate your reply. Does the "Oily toucinh attact a lot of dust. I live in an area, in the country, where the wind blows quite freqently. However I will try any thing. I have found Armorall to be too shinny and collects a lot of dust.
