Best wax for Silver Cars?
aespino
Hi. I have three Silver cars. Which wax would you consider to be the the best for this color, Fuzion or Black Label Synergy. I've tried Fuzion with great results and have now read about Synergy. Which is better? I'm confused.
Your help is appreciated!
Personally I like sealants on Silver, like Menzerna Power Lock.
I would go with fusion as far as a silver car,on the other hand if it were black I would opted for synergy for more depth.There are limitation to waxing a silver car for aesthetics looks so fusion would be a good choice if there is no polishing done.another great product is 4 star weather paint protection with poly booster in it,I use this stuff on almost every thing.
From my understanding of LSP categories:
Both Fuzion and BL Synergy are "Hybrids"...
not Finishing Waxes.
So...IMO:
Since you've already tried Fuzion; and, unless
you're going to rely solely on anecdotal accounts;
the best way for you to find out if Synergy is
"better" than Fuzion (or not) is to do a side-by-side
comparison on a vehicle's panel---say, like a hood.
For something that's a wax, I like collonite 845 on silver. For a sealant I like menzerna powerlock on silver. In general powerlock is easier to use than 845. Either should give you similar durability.
These are the two I have on my car and it looks great:props:
I personally like the way sealants look on my silver car. No much depth can be achieved with a color like silver, at least in my opinion. However, with sealants, the gloss is substantial. I personally use Wolfgang or Blackfire sealant.
The truth is, its what you do before you apply a wax or sealant that is going to have the biggest impact in how the paint looks than a wax or sealant alone. The key is in the prep!
I've seen Optiseal give some good looks to silver....durability isn't the greatest, but because it's soo easy to apply u can top it up every month or two
Collinite 915 as a wax did wonders for the shine on an Acadia I owned.
Fuzion on my silver car looks great. I used Opti-Seal as the base. I still like Opti-Seal, but Fuzion gives my car a totally different look.
I go back and forth between Fuzion, Wolfgang Deep Gloss Paint Sealant 3.0, and Blackfire wet Diamond.
On my daily driver sitting outside 24/7, I have found G-technic to look great. I use their spray to boost the beading and glossy look every other week.
I have been using collinite 885 for years but have ordered the Wolfgang super gloss sealant and füsion wax to try.
Having own both Fuzion and Synergy, I will recommend you to go witg Synergy. Many peiple still believe that Synergy will give the same look as Souveran without using them, no, no, no. Synergy unlike Souveran, are much more glossy look on the paint, while souveran will give you deep wet result, they are totally different look.
Now come to compare Fuzion VS Synergy, both of them are in term of Glossy look, however Synergy is more Glossy, more depth (not as much as Souveran) and more durability than Fuzion.
Go for Synergy, it's on sales now, I almost can't resist but still have them left in my arsenal, and it can be use for a long long timeeee.
