dieselfan1
Member
- Apr 1, 2021
- 247
Like these....
No wayDe-badge
De-badge
No way
I paid big buck for those.
If I took them off it would look like any other Silverado.
You debadge an LT not a HC.
Another vote for de badge.
How are folks choosing to debadge? By using floss? Fishing line? The last time I debadged was over ten years ago and I used plenty of floss.
This^^^I use fishing line then a 3m rubber wheel.
If you are not debadging, I recommend a soft brush, and a water spot remover if there is a lot of build up. In some instances, when I have a client that uses the automatic car wash alot, those areas are never cleaned right. Only way to get them clean without debadging
Yeah a boars hair or detail or a detail factory ultra soft brush if paint is soft. I use to do in snow foam stage but now do as Opie does and just use bucket wash soap.
De-badge
I used a hair dryer to heat it up. Then I used fishing line, which mostly separated the badge from the adhesive. The foam adhesive was easy to roll up/off of the car. Followed up with goo gone.
I still do mine in the snow foam stage. Did you notice some negatives doing it this way that made you switch it up?
