By chance, do you mean the calipers? If you're actually talking about rotors, there's not a whole lot you can do to keep them "clean." The first time you brake while driving will remove the surface rust that forms from getting wet. The outside edge of the rotor will naturally rust if they aren't coated/plated, but you can always take the wheels off and hit those areas with a wire wheel.
Mark
You can blow dry them with a leaf blower.thansk for the info, will test the driving down the road braking solution, hope that does it, the rust color drives me nuts, thanks again for the responses. Scott
:dblthumb2:
