Best Way to Polish 40 year old Lacquer Clear Coated Aluminum Wheels
Since1977
Hi,
I acquired an original set of mid 70's OEM Corvette slotted aluminum wheels. I know these were clear coated with lacquer (single stage) from the factory, and it appears that the finish is still there (how can I tell for sure?).
However, there are a lot of whitish spots on the wheels, which look like water spots but I believe this is oxidation of the lacquer clear coat.
What products and process should I use to restore the wheels and remove the spots? I intend to do this by hand, and do not want to damage the lacquer clear coat.
Thanks much.
Dave
Clean them thoroughly, then use a light colored MF towel and a white polish (for paint). If after a few rubs, you see a lot of black on the towel, then it is bare aluminum. Try a second time in the same spot just to verify it wasn't just 40 years of grime coming off. If it's very black the first time, it's a near certainty that they are bare aluminum.
Polish by hand with a MF towel and polish like
Meguiars m205 or optimum finish
I doubt those white spots are going to be fixed by polishing. Probably have to have wheels professionally refinished.
I would get some Mother's Mag wheel and aluminum polish. Clean the wheels real good then rub a little on an inconspicuous spot with a white towel. If it turns black then they are probably bare aluminum. Otherwise I would use just a fine abrasive paint polish on them.
Thanks for your responses, and here is an update:
I rubbed some polish on the wheels and got a grey/dark grey residue on my polishing cloth only when rubbed hard, not the dark black that comes with oxidizing aluminum. So I assumed the lacquer clear coat is still intact. On the theory that old lacquer clear coat is just like old single stage paint, I applied Meguiar's number 7 with a terry cloth towel to the wheel with the most white oxidation spots. After two hours of repeated application and rubbing, I reduced the spotting by about half. In the process I think I further confirmed that there is indeed clear coat, since some of the spots when rubbed transitioned to a yellowish tint, which seems consistent with lacquer.
My question is, what is a good polish to gently remove the remaining water spots / oxidation once I am finished with the Meguiar's 7? M205 was suggested, are there any others? Doing this by hand.
M205 is a fine cut polish, I would invest the time and energy to apply a fine cut polish.
Might as well go with a true compound. If you want to keep it simple and stick with Meguiar's then get some Ultimate Compound and apply with terry cloth.
Thanks so much Mike.
Do you mean that you would skip the fine polish and go straight to Ultimate Compound?
I suppose then that the Ultimate Compound is gentle enough to the lacquer if applied by hand...
Dave
Dave
I would apply the Ultimate Compound and then seal. You're not going to see a dramatic difference between any other steps on clearcoated aluminum mags.
I've actually owned quite a few slotted mags...
Old School Aluminum Slotted Mag Wheels - Extreme Makeover
Before
After
