best way to use white pearl tire dressing?
pedro123
hello, guys, new to the forum. im going to order a gallon of the showroom fx white pearl tire dressing but i was wondering the best way to apply it to an application pad. use a spray bottle or a squeeze bottle like this?
thanks
:welcome: To Autogeek Online!! :props:
Did you start a membership in order to tell us you were buying a product that's not carried here? Nice start!! :p
OH, and thanks for the :spam4:
thanks
Send me your bottle and I'll report back to you how to apply it
im actually trying to do a test between white pearl and carpro PERL
A little more information in the beginning would have resulted in more constructive replies.
It really depends on the viscosity of the product you're using.
CarPro PERL, diluted, is easily spray-able laying down am even coat to soak in. I've used PERL many times with great results.
Thicker products lend themselves well to be applied with a brush or foam rubber pad. Like I said, it depends on the liquids viscosity....
i will be using the PERL 1:1 and the white pearl full strength
Well with a gallon you will certainly have enough to do side by side trial for a while.
since both of these dressing are watery, whats the best way to apply it to the application pad. squeeze bottle or spray bottle?
I use a squeeze bottle but I recently got some Blackfire tire dressing and it has a sprayer on it. I think it's pretty nice to just spray the applicator. I think it's cleaner too since I don't have anything drip on the bottle.
I say use a sprayer.
I use both CarPro PERL and Wolfgang Vinyl Protectant.
The Wolfgang Vinyl Protectant is used straight, no thinning or diluting required.
The use CarPro PERL thinned 1 part PERL to 3 parts water. I feel this is the perfect solution for both exterior trim and well as interior surfaces and trim. I have reduced PERL 1 part PERL to 5 parts water for interior use for fantastic results....
CarPro PERL
Both products apply well using a standard spray bottle.....:props:
